Displays the IP Address Resolution Protocol (ARP) table. You can filter the display by IP address, MAC address, VLAN, or permanent entries.
| ip_addr | Specifies an IP address. |
| mac | Specifies a MAC address. |
| vlan_name | Specifies a VLAN name. |
| vlan_list | Specifies a VLAN list of IDs. |
| permanent | Specifies permanent entries. |
| port | Show entries for a specific port. |
| port | Show only entries for this port number. |
| vr_name | Specifies a VR or VRF. |
Show all entries, except for proxy entries.
If you do not specify a VR or VRF, the command applies to the current VR context.
The show output displays the following information:
| ARP address check | Whether IP ARP checking is enabled or disabled. IP ARP checking verifies if the ARP request‘s source address is in the receiving interface‘s subnet. |
| ARP refresh | Whether ARP refresh is enabled or disabled. ARP refresh is performed when an ARP entry‘s age is three-fourths of the timeout value. |
| Dynamic entries | The number of dynamic (learned ARP) entries in the table. |
| Pending entries | The number of sent ARP requests that have not yet received a response. |
| Static entries | The number of configured (static ARP) entries in the table. |
| Timeout | Timeout value for a dynamic (learned) ARP entry. |
| ARP Global Settings | |
| Max Entries | Maximum number of ARP entries. |
| Max Pending Entries | Maximum number of pending ARP entries. |
| Max Proxy Entries | Maximum number of proxy ARP entries. |
The following example displays the IP ARP table for the current VR or VRF context:
# show iparp VR Destination Mac Age Static VLAN VID Port VR-Default 10.10.10.6 00:04:96:1f:a5:71 8 NO bluered 4092 1 VR-Default 10.128.32.1 00:01:30:ba:6a:a0 0 NO Default 4095 VR-Default 10.128.32.2 00:01:03:1c:ae:b0 5 NO Default 4095 VR-Default 10.128.32.4 00:d0:59:17:74:83 3 NO Default 4095 VR-Default 10.128.32.5 00:02:a5:c2:5c:dd 0 NO Default 4095 VR-Default 10.128.32.6 00:12:3f:1c:f8:fb 5 NO Default 4095 VR-Default 10.128.32.7 00:11:11:80:9c:b9 7 NO Default 4095 VR-Default 10.128.32.8 00:11:43:53:8e:f1 0 NO Default 4095 VR-Default 10.128.32.9 00:02:a5:bf:ac:70 7 NO Default 4095 VR-Default 10.128.32.10 00:11:43:44:18:68 10 NO Default 4095 VR-Default 10.128.32.11 00:12:3f:1c:e9:f2 0 NO Default 4095 VR-Default 10.128.32.12 00:02:a5:bf:af:79 8 NO Default 4095 VR-Default 10.128.32.13 00:11:43:40:89:91 0 NO Default 4095 VR-Default 10.128.32.16 00:0f:1f:c9:2d:80 2 NO Default 4095 VR-Default 10.128.32.17 00:06:5b:b1:6a:91 1 NO Default 4095 VR-Default 10.128.32.19 00:11:43:3a:96:1d 10 NO Default 4095 VR-Default 10.128.32.20 00:08:02:d5:c5:b7 6 NO Default 4095 VR-Default 10.128.32.24 00:12:3f:0a:44:92 14 NO Default 4095 VR-Default 10.128.32.26 00:50:04:ad:36:5e 6 NO Default 4095 VR-Default 10.128.32.30 00:b0:d0:23:f2:9a 11 NO Default 4095 VR-Default 10.128.32.54 00:b0:d0:59:e4:e2 6 NO Default 4095 VR-Default 10.128.32.55 00:a0:c9:0c:41:de 3 NO Default 4095 VR-Default 10.128.32.59 00:b0:d0:7c:d6:07 14 NO Default 4095 VR-Default 10.128.32.99 00:04:96:05:00:03 13 NO Default 4095 VR-Default 10.128.32.101 00:04:96:1f:a8:48 0 NO Default 4095 VR-Default 10.128.32.104 00:30:48:41:ed:45 0 NO Default 4095 VR-Default 10.128.32.105 00:30:48:41:ed:97 0 NO Default 4095 VR-Default 10.128.32.106 00:01:30:23:c1:00 0 NO Default 4095 VR-Default 10.128.32.108 00:04:96:1f:a5:71 0 NO Default 4095 VR-Default 10.128.32.116 00:04:96:1f:a4:0e 0 NO Default 4095 Dynamic Entries : 1 Static Entries : 0 Pending Entries : 0 ARP address check: Enabled ARP refresh : Enabled Timeout : 20 minutes ARP Sender-Mac Learning : Disabled Locktime : 1000 milliseconds Retransmit Time : 1000 milliseconds Reachable Time : 900000 milliseconds (Auto) Fast Convergence : Off ARP Global Settings Max Entries : 4096 Max Pending Entries : 256 Max Proxy Entries : 256
The vr option was added in ExtremeXOS 11.0.
The vlan_list variable was added in ExtremeXOS 16.1.
For ARP, virtual network remote endpoints appear in the port column in ExtremeXOS 22.3
In Request, Out Request, Failed Requests, Proxy Answered, Rx Error, Rejected Count, Rejected Port, Max ARP entries, In Response, Out Response, Dup IP Addr, Rejected IP, Rejected I/F, and Max ARP pending entries output removed; ARP Global Settings Max Entries, Max Pending Entries, Max Proxy Entries output added in ExtremeXOS 30.1.
